factory ecu on 20 lb boost ?possible? - FirebirdV6.com/CamaroV6.com Message Board
  • factory ecu on 20 lb boost ?possible?
    hi, i am doing up a 3.8 v6 turbo, from a vn commodore (australian).
    i have most of it ready, but am still working out what to do with the ecu side of things.
    the original ecu is a `808 with map.
    is it possible to modify/swap etc.....to get a factory ecu to run with 20 lb of boost?
    any ideas?
    thanks.
    I just put a turbo on my 3.8 camaro.
    20psi is a ****load of boost. I only use 7psi.
    Get some tuning software like HP tuners or DHP. I have DHP, and it is helping me.
    I compensated for larger fuel injectors.
    I am currently mounting the MAF sensor in front of the turbo, for a draw thru setup.
    I also pulled a few degrees of timing.
    SInce you have a MAP sensor, I think you need to get a 2 bar MAP upgrade and program the PCM for it. I don't know a whole lot about MAP stuff, since I have MAF.
    these guys might know more than we do here.
    www.3800tech.com
    www.hptuners.com
    www.clubgp.com
    they all work on grand prix's with 3800 v6s.
    1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
      We have a MAP as well, it's just that the MAP is mostly used as a check to macke sure the MAF is reading properly.
      Matt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
