I posted a little while ago on how I was going to rebuild my 3.8L engine this summer and was going to buy a used one to put in till its done. My question is if the engine has sat for a while i'm sure the oil in it has drained down and parts are not lubricated well. So is there any way to get the engine lubricated before I start it, I want to stay away from dry starting it as much as possible so I would not hurt it.
New Engine
Pull the fuel injector relay and ICM relay (Or just pop the wires off the coil packs.
Then just crank it for about 15 seconds.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
If you have this engine on an engine stand that rotates. Rotate it all the way around once. Oil will fill the valve covers and then flow back down. Can't get more prelubed than that. Really, if it's been sitting for less than a year in a sealed state(not missing spark plugs or valve covers/ all holes capped off), as a used engine should be before you buy it, you won't need to do anything.\'94 Camaro 3.4<br />\"No, Starvin Marvin. That\'s my pot pie.\"
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...1 week ago
by ssms5411Getting a message saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...1 week ago
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.2 weeks ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...2 weeks ago
