i have researched the topic and not found instrctions on how to install the jetscu2000 i just changed gears and need to hook it up i bought it a while back so where does this thing plug in at??
Jet scu2000 installation
1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>Tags: None
see i bought mine used so i did not get the instructions :( so i am trying to get some i am doing it soon very soon actually i am going to try and do it thurs. or fri. depending on how much time it takes to fix my pinion seal leak and take that damn 2pc ds off finallyi will take pics if you want1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
edit: ahh let me advise this was done on my '99, so do what you will with my install instructions, the VSS might be located in a different spot
let me see if i remember....
i tapped the power source into one of the headlamp fuses in the fuse box. you need to route the tubing through the engine bay and use strap ties where necessary so it won't melt. the VSS is located on the passenger side just after the cat (its way up in there so don't attempt this until the car has cooled down or you will burn yourself on the cat!!)...unplug the VSS and attach it to one of the scu2000 plugs and plug the other side into where the VSS used to be plugged in.
shady description but thats how it goes [img]smile.gif[/img] also disconnect the neg battery terminal before you start!
[ May 06, 2002: Message edited by: TheBeast ]</p>
hey southern-- are youleaking gear oil from the swap? i think mine is leaking too..i brought it back to the guy he said he overfilled it and thats y its leaking..but its been like 2 weeks and still leaking?? should i bring i back?94 3.4L A4 white t-tops<br />moroso cai<br />3\"hi-flow pacestter exhaust<br />b&m shift kit<br />catco cat<br />01 T/A rear w/ 3.73\'s and posi<br />1 pc aluminum ds<br />blacked out signals
over filling will cause it to leak yea mine is leaking from the swap but that is because i damaged the pinion seal (ironman24 cough*) but i have to replace it get under your car and see if it is leaking where the ds is connected to the housing if it is the pinion seal is bad but i doubt it probley just overfilled and ti will leak out the vent at the top of the housing.
as far as the jet not to be rude man i am really stressed out with exams but i have no damn clue to what your talking about i don't know what the vss is or where it is located and i did not know i needed a power source haven't really looked at it i know the jet chip i put on the computer did so makes sence lil more info if you can like where this vss is at?? i can get a power down there no prob.1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
<blockquote>quote:</font><hr>Originally posted by southern94:
as far as the jet not to be rude man i am really stressed out with exams but i have no damn clue to what your talking about i don't know what the vss is or where it is located and i did not know i needed a power source haven't really looked at it i know the jet chip i put on the computer did so makes sence lil more info if you can like where this vss is at?? i can get a power down there no prob.<hr></blockquote>
well, now that i check Jet's website, they do not have a Jet scu2000 listed for the '94 3.4.... so that could mean that it might not work for your car. The VSS is the Vehicle Speed Sensor.
i was told it works for 94 and up it says it on the site where is the vss located on the car?1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
well **** i reckon i will have to sell it1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
i hope your right southern---
how do we fix our speedo after gear change?
i thought we could use the SCU2000...i guess not :(94 3.4L A4 white t-tops<br />moroso cai<br />3\"hi-flow pacestter exhaust<br />b&m shift kit<br />catco cat<br />01 T/A rear w/ 3.73\'s and posi<br />1 pc aluminum ds<br />blacked out signals
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...1 week ago
by ssms5411Getting a message saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...1 week ago
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.2 weeks ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...2 weeks ago
