Valve train - FirebirdV6.com/CamaroV6.com Message Board
Valve train
  • Valve train
    So I need to replace a lifter. I have basic knowledge(learning everyday from you all thanks) and a chiltons manual. Is this something a novice could handle? i hopr this belongs here...
    \"If I have seen further, it is by standing upon the <br />shoulders of giants.\" (Isaac Newton)
    Replacing a lifter is definatley something you can do yourself, but it takes a little bit of knowhow and a whole lot of cussin', especially with the engine stuffed underneath the dashboard. Read what the chilton's says about doing it, and see if it's something you think you can do.
    BTW:This probably goes in "Drivetrain" Don't worry, they will move it for you.
    -Jason<br />Black 1993 Pontiac Firebird -Retired<br />Black 2002 Pontiac Trans Am -Sold-<br />Green 1996 Corvette Convertible -Sold-<p>In the market for \'67-\'73 Firebird!
      if you have small hands, a lot of patience, and the right tools, do it yourself. If you wanna go on the safe side, have someone else do it who knows what they're doing. while you're at it, get a higher ratio lifter kit for more hp.
      2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
        Patrick do you know were I could find a set of higher ratio lifters? Or does anyone know.
          Ok if I decide to replace the one that is sticking how do I find it? Or should I just replace them all? i still havent found any high ratio lifters....Thanks for the help
            just replace the bad lifer you can get away with that with a roller cam (if ya had a 3.4 you would have to replace all the lifters and the cam becase flat tappet lifter wear to the cam)
            i've heard of higher ratio rocker arms(i don't know where to get them for a 3.8 tho..) but i've never heard of higer ratio lifters
              I don't think there is such a thing as higher ratio lifters, I bet he meant rocker arms. If you are going to replace one lifter, you should probably replace them all. You can test them once you take them out though, should be able to figure out which one is sticking.
                <blockquote>quote:</font><hr>Originally posted by Blue Jay:
                I don't think there is such a thing as higher ratio lifters, I bet he meant rocker arms. If you are going to replace one lifter, you should probably replace them all. You can test them once you take them out though, should be able to figure out which one is sticking.<hr></blockquote>
                How do you test them? We dont want to replace all of them if we dont have to. There $42 a piece. If we can just replace the lifter that is sticking it should be fine. $500 for lifters dont sound like too much fun. How do you test the lifters once there out?
                  test hydraulic lifters with leak-down test.
                  if you plan on changing rocker arm ratio, i'd suggest using a little stronger valve springs as well.
                  ASE Master, L1, X1, C1. Instructor in automotive systems. 99 3800 4L60E with a few mods and a greatful dead sticker on the back window.
