4 valve heads being produced - FirebirdV6.com/CamaroV6.com Message Board
  • 4 valve heads being produced
    Over at the Grand Prix forum, we have gotten Arao (famous maker of 4 valve heads for SBCs) to produce some for the Series II engine. Confirmation has just been given today and info is just starting to come in. for more info check out here: http://www.clubgp.com/newforum/tm.as...mode=1&smode=1
    im not 100% sure if our heads will bolt on to yours (do you have a different LIM? but im sure it is a step in the right direction for the series II engine.
    Edit: i just talked to zooomer and he said that our heads are interchangable so they would be able to fit too
    [ March 01, 2005, 07:21 PM: Message edited by: stuffy236 ]
    01 Grand Prix GT- 3\" DP, custom CAI, 180* Tstat<br /><br />I dont have a Fbody, but i will once im out of college...mmmm RWD L36.....
    wow, thats pretty interesting..
      Well out heads are interchangable to a certain degree... I assume these heads are for GTPs, which they will fit on your block but not bolt up exactly the same...
      we just need someone to do a roots blower in a v6 [img]smile.gif[/img]
        GTP and GT (L36) heads are interchangable and the 4 valve heads will fit GTs also
          I thought the injector bosses were in the heads on the GTPs?
          Matt
          1998 Mystic Teal Camaro M5
            they are but there are ways to still use them. I still say a hemi head would be better but i will take a look at this.
              Yes, they will swap... I've seen a certain v6 f body around here... who doesn't run f body heads on his v6 f body ;)
                Hmmm, aluminum heads should be right up your ally james. Imagine the weight savings :D .
                  Too costly... I draw the line somewhere [img]smile.gif[/img]
                    I hear ya, it looks like a good option but i just cant afford it. I'll stick with my decision to go with abbott.
                      you have a neon, so what ever l,ine there was w/that was crossed [img]tongue.gif[/img] [img]graemlins/stickpoke.gif[/img]
                      roots blower for the L36.... this might do it add 4v heads..... [img]graemlins/burnout.gif[/img]
                      2013 Ram 1500 Big Horn
                      94 comero 3.4
                        Are they going to make this work with an OHV setup? Or will they have to work in an OHC valvetrain?
                        I'm having a hard time picturing how this will work, going OHC would seem more reasonable to fab up than having 24 rocker arms, pushrods, lifters etc. Or is there some way that one rocker actuates two valves in this setup?
                        -1999 Camaro Coupe 3800 Series II V6 A4 - SOLD<br />-1998 Pontiac Grand Prix GTP coupe
                          they stay ohv, it uses forked rockers to push open both valves at once
                            32v chebby head http://www.araoengineering.com/Chevy...hvy_smb_lg.jpg
                            94 comero 3.4
                              this would be amazing if it worked out...imagine the hp gains with these heads p&p'd plus a nice cam. wouldn't even have to be that big. we'd gain a lot more top-end power too wouldn't we? this is so awesome im really excited to see this come to fruition. 300+ hp n/a may not be that far away....
                              i may have to re-think selling this car
                              V-SEX!<br /><br />intake/exhaust ;)<br />plenty appearence<br /><br />Within my grasp: 14\'s :)
