I went to a shop to have the engine flush and the shop said thay wont do it because there was alot of that rad sealent in the system.Than he said there was a little trace of oil in the coolent.
He than said it might be the head gasket or engine block cracked.To look at the engine you cant see any wet spots on the outside of thew engine.
What should i look for?Where do i go from here?I want it fixed but i also like to know what the problem is.
If it's the engine block than i dont know what i want to do with it.If it's the head gasket's than i'll replace them.
So where can oil get in the coolent?
