would a 1997 camaro 3.8l motor bolt right up to my 1999 camaro transmission without any prablems. I pretty sure it is the same motor but im just making sure
Engine swap question
Use the long block from the 97 and put your 99 upper/lower intake on it, then you will be good to go. I put a 96 motor in my 98, bolted up fine to the T5 tranny.Michael Huff<br />92 RS, 98 V6, 97 SS, 00 Z28 <br /> <a href=\"http://www.carolinafbodyclub.com/\" target=\"_blank\">http://www.carolinafbodyclub.com/</a>
