Im getting very frustrated with the 3.8, Why would my oil smell like gas?
Oil filter smells like gas, opinions needed
because when the motor runs, a little bit of fuel goes by the rings into the oil... if u run race gas it makes the oil smell good!!!<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
Change your oil. If your oil smells like gas change it. This is how i siezed my 3.8 motor. I didnt find out why the fuel was in the oil but there was lots of it. I had the oil analyzed. Change your oil, keep a close eye on it, if problem keeps happening fix it. I think i could have saved my 3.8 if i just changed the oil.
<blockquote>quote:</font><hr>Originally posted by cammed3800:
You wouldnt think the rings were worn on a motor with 500 miles would you?<hr></blockquote>
if the block wasnt honed properly then they might not have set correctly
did you use stock replacement rings or chromoly rings? chromoly rings are notorious for taking a long time to set up (im talking a few thousand miles) so if you have chromoly rings give it a few more miles before you worry about it-Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
It was built by a reputable machine shop who builds race car engines. I think they are regular rings
I did a compression test with the motor warm and the throttle wide open all were 145-150 psi i then added oil in the plug holes and most stayed the same, some rised maybe 3-5 psi seems like my internals are fine, maybe it just needs dyno tuned
pgriffith, do you have any ideas why yours seized up?<hr></blockquote>
No. I havent even bothered tearing down the block to see what exactly happend yet. my guess is she was just rode hard and washed up wet.
[ December 08, 2003: Message edited by: pgriffith ]</p>
check your PCV system. the PCV should pull the most of the vapors out of the crankcase b4 they have a chance to get into the oil. some is to be expected. check the PCV valve and make sure u dont have a lose or missing vac line for it
matt-Matt<br />Manager/Tech Support<br />Precision Speed & High Performance<br /><br />visit us on the web at:<br /><a href=\"http://www.precisionspeedonline.net\" target=\"_blank\">www.precisionspeedonline.net</a>
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...18 hours ago
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....5 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.5 days ago
