just go in, isn't there a way you can advance the timing thru the crank and timing belt? i wonder if anyone has tried this? just advance the timing like 3 or 4 degrees or so thru the belt?
why all the timing advance gimmicks?> why not...
The belt method is for distributor cars. We have DIS ignition systems.
The PCM sends a signal to the ICM (Ignition Control Module) which then distributes that signal as spark to the correct cyl based on signals it gets from the crank and cam position sensors.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
The timing chain connects the cam to the crank. Any adjustment you do to that timing chain will affect the valve timing events, not spark advance.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
nah dude you don't wanna go playing with valve timing. leave it where it is, with the dots lined up... there is a BIG difference between ignition timing (what you are trying to play with) and valvetrain timing (what you would be playing with messing with timing chain/belt)
the pcm will automatically kick the timing up as much as it needs before it senses detonation, especially at low-load wide-open throttle. trying to alter ignition timing will most likely result in poorer performance if you are able to change performance at all.
as mentioned before, the pcm calculates the correct amount of ign timing advance by looking at many sensors (any load-related sensor like ckp, ect, tps, vss, maf/map...) actual ignition timing is sensed by the crank sensor (3x and 18x signals)
it does not look at cam sensor for ignition though. cam sensor is just reference for cyl 1 tdc compression for sequential fuel delivery.
[ May 09, 2002: Message edited by: strange_trp ]</p>ASE Master, L1, X1, C1. Instructor in automotive systems. 99 3800 4L60E with a few mods and a greatful dead sticker on the back window.
