V-8 Swap Crazy thought? - FirebirdV6.com/CamaroV6.com Message Board
  • V-8 Swap Crazy thought?
    Anyone ever drop a Cadillac 500 cu in V8 in a f-body. I have a 94 V6 not doing much thought it would be fun. That 500 produces 300+ HP and almost 500 ftlb torque. Crazy thought????
    Yep. Have fun.
    94 Firebird 3.4 - RIP<br />97 Firebird 3.8 - In the works
      wow 300 horsepower! what could you ever do with all that?
        300hp is pretty weak for a 500ci motor
        1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
          waste the money on modding the V6 and take it up to 300hp, thats where Im headed!
          2000 3800 II V6 Firebird<br />various small mods, bigger stuff later.
            Ive got over 300hp at the crank with heads/cam on a stock shortblock. I'd save the trouble of trying to swap that motor and just work on the V6! [img]smile.gif[/img]
            <b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
              Those caddy engines are pieces of ****. You'd be much better off selling your car and buying an LT1 car. You'd gain reliability, fuel economy, plus it would be cheaper.
                Or you could put the caddy motor in, mod it and do sick wheelies with all that torque...
                \'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
                  Thats what i thought. The specs said that motor had 375hp but a one stock one dyno's at 323hp @ 3600rpm and 504lbs of torque @ "2600 rpm". This only 60 lbs hevier than a short block bowtie. With headers, mild cam, intake, and carb it was pulling 440 hp and 565ftlbs. keep in mind one of these motors can be had for a couple hundred bucks and the mods cost less than $700. lot of power for a little bit of money. i've seen these drag racing in a el camino fully modfied with heads and radical cam. ran in the high 9's.
                  Even at a stock setup i don't see how fuel mileage would be a problem with all that low rpm torque.
