Would O2 sims cause my car to run bad?? Bad as in hesitation, and stumbling. I know for a fact that my injector signal to the #1 and #3 cylinders are weaker than the rest. Would the sims have anything to do with it?? I just ordered another ECM, and it is going in with my engine and turbo, but this problem has been plauging me since last summer. I dont want to cook my engine for the 4th time once the turbo goes on again. Please put all your inputs in on this. You helping the future fastest V6 on the board once I build my new engine and pump over 20 PSI [img]smile.gif[/img]
[ March 30, 2003: Message edited by: Formulao96 ]</p>
New Car--- 2000 Trans Am M6--SLP Lid, K7N Filter, 160 degree Thermostat, Loudmouth Exhaust, Smooth bellows, MAF ends, ASP Pulley, 4.10 gears, Y2K Chrome Vette Wheels, 2\" drop.. More to Come<p>Dyno <br />325 RWHP <br />325 RWTQ<p>Cardomain Site <a href=\"http://www.cardomain.com/id/formulao96\" target=\"_blank\">www.cardomain.com/id/formulao96</a>
The post cat o2 sensor is only there to tell the computer how well the cat is working. A o2 sim in it's place feeds back a signal that tells the computer that there is a cat there when there isn't. That sensor has nothing to do with how your car runs. If you have them on the sensors before the cat then yes, that would be a reason that your car doesn't run right. There is no reason why they should be put there unless your looking to burn up an engine because you could be running extremely lean and your computer couldn't devance the timing to save you from melting things.
1997 Nassau Blue Vette<br />1989 Jeep Cherokee 4x4 (lifted with 31\" tires)<br />2000 V6 Camaro, loud, cammed 210rwhp *SOLD*
I have had a problem with my RK sim throwing codes. So be careful.
2001 Blue Firebird.<br />V6 M5. free ram air mod, 3\" pvc intake, Air temp module, 3\" exhaust, Dynomax 3\"straight through exhaust, O2 sim with off road pipe.<p>Kenwood kdc-mp919 head unit, kfc-628 and kfc-748 amps, Kicker I650 mids/highs, 12\" kenwood WS-303 sub<br /><a href=\"http://www.trafficjamzcaraudio.com\" target=\"_blank\">www.trafficjamzcaraudio.com</a><p>1500 years ago the world was the center of the universe. 500 years ago the world was flat. 15 minutes ago we were alone on this planet. Just think what you will know tomorrow.
3 days ago
