Kris, just like you told me every major install has its down falls and problems. But you got that **** in and did a damn good job of doing it.
Update: Heads/Cam is Finished Sound/Video clip inside
Well today i went back and retourqed the rocker bolts down at TDC and i grinded the underside of the rockers to allow for more clearence cause of the straight coil spings and my KR went from 14.9 to 9.8 KR This KR i got from 1000 to 2000 rpms so it has got better i will do the other side tommarow and pump in some 93 octane i still had a 1/4 of 87 octane whice is a no no. SO i lost alot of KR and i have only finished one side so far. Damn Weather<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
Looks good and sounds D@MN good !! mad props! quick question do you happen to know the part# of the gasket in between the upper and lower intake or do you use a RTV sealant or something... i have to take my inake off this weekend cause its leaking like a mofo, i have all the other gaskets except that one. Thanks for any help and d@mn good job again. [img]graemlins/fluffy.gif[/img]AIS 2 OHH the memories... Great times and putting names with faces.<p>From \"interesting\" hooters waitress(Did you guys FLY ? ) to pissing BMW owners off on the ride home. To ending up in Philidelphia and USING (hahaha) an ice machine. I had a BLAST.<p>Thanxs to all that showed up!!
For your year part number for the intake gasket kit whice is upper and lower is GM-12537616
I used some RTV to seal on the lower intake gasket it is a little block that goes on the front and rear of the lower intake.
[ April 07, 2003: Message edited by: slacker69 ]</p><b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
thanks on that tip for sealing those litle blocks.... and once again looking good ;)AIS 2 OHH the memories... Great times and putting names with faces.<p>From \"interesting\" hooters waitress(Did you guys FLY ? ) to pissing BMW owners off on the ride home. To ending up in Philidelphia and USING (hahaha) an ice machine. I had a BLAST.<p>Thanxs to all that showed up!!
