i am contemplating buying a used valvetrane from a member on here who claims that it was only used for 2500 miles. i haven't seen it in person, so i am cannot physically inspect it, but generally is this an ok thing to buy used, or should i just buy new and be reassured. Thanks in advance. Also, would i be safe buying pushrods and lifters, and springs, and then buy retainers, and roller rockers new?
Used Valvetrane good idea?
its your call...your taking a risk on anything that is used. look through his posts and see if hes honest or helpful that should help you decide if the 2500 miles is probably accurate.
if the price is right....go for it1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
I have used Titanium valves for the Z28's heads.
There used but look at the alternative >$100 for a used set (intake $150 or exhaust $60) or $100 a valve new.
I'm reuseing the valves on my heads for the V6 there Ok as long as there not bent or warn down to less then .090'' thickness below the seat on the exhaust valves, intakes can be thiner.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
Most parts should be okay if they were only used for a short amount of time. You should definitely get new lifters though with your new cam.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
Yes replace them unless there rollers.
It is very hard to bring flat tapet lifters back to life for reuse, you have to resurface them. Any thing over about 2000 miles is a no.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
i wouldnt think a blown piston would do anything to the valvetrain unless it did some pretty major engine damage. did he just burn a piston or throw a rod or what? its hard to say without actually seeing the engine or even knowing what happened1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
Originally posted by whiteThunder:
so go for everything but new lifters. also, josh what is the diff between the two roller options in your valvetrane package? and how fast can you ship, because ur my next stop. also, do lifters come with most cams, or separately?- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
