I'm about to attempt to pull out my motor and transmission, any tips you guys would have? I'm lookin for stuff that may have had u stuck for a while that u finally found a solution to. Things I should do before other things. Just some general advice on the whole thing.
Anyone who has pulled their 3.8, please read
I would have to say that if you have the space, dropping the engine out the bottom is the way to go. I did this on my 95 firebird(3.8) and it was very smooth. i can tell you how i did it, and i have a couple of pictures if you email me @ gtg602b@prism.gatech.edu
if you take it out the top take the upper intake off first, it makes it alot easier, its faster putting it in then taking it out i found that outLongtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
My motor has been pulled about 3 times soo far, all 3 have been through the top. Only LT1s and LS1s have to be dropped through the bottom. Be careful not to hit the windshield on the way out or in, and be sure to support the engine once oyu drop the tranny out, or it might tilt back and crack the bottom of your windshield.New Car--- 2000 Trans Am M6--SLP Lid, K7N Filter, 160 degree Thermostat, Loudmouth Exhaust, Smooth bellows, MAF ends, ASP Pulley, 4.10 gears, Y2K Chrome Vette Wheels, 2\" drop.. More to Come<p>Dyno <br />325 RWHP <br />325 RWTQ<p>Cardomain Site <a href=\"http://www.cardomain.com/id/formulao96\" target=\"_blank\">www.cardomain.com/id/formulao96</a>
Every motor pull I've ever helped with was from the top, that includes many LT1's. I pulled mine from the top. Plenty of room in there. Pull the upper intake off and use the stock "handles" on the front drivers side head and rear pass side head. Getting the oil pan to clear the k-member is probly the biggest challenge, just have to tilt the motor a bit.Michael Huff<br />92 RS, 98 V6, 97 SS, 00 Z28 <br /> <a href=\"http://www.carolinafbodyclub.com/\" target=\"_blank\">http://www.carolinafbodyclub.com/</a>
