i think you misunderstood me. I want to get an l67 engine (so that i have the lower cr, and stronger rods) and put an aftermarket cam in it. i forgot to put a comma in after l67. I know the l67 has the same cam.
4.2 stroker kit
I want this kit now... NOW! Siiiiiiiiiick! Gonna need to start saving money like mad. :picks penny off floor: Keep updating with everything you find out [img]smile.gif[/img]
[ March 09, 2005, 09:54 AM: Message edited by: 99v6cam ]\'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
[img]graemlins/bowdown.gif[/img] [img]graemlins/banana.gif[/img]
If only fluffy was here, he would be jumping around like crazy. :D2000 V6 Camaro(bought brand new)
5 speed
Project: Unreal
Several Mods..:naughty:plus Nitrous=WEEeee:banana:
2007 Suzuki GS500F :D
Daily driver
2007 Chevy Aveo 5
Mods K&N air filter:excited:
www.guardiansworlds.com
Yup, the holdens use the 3800v6 only they call it an ecotec. I already talked to them and they said it would work fine in the buick 3800II. They also said that if you want just a billet crank you can get it for about 2k. After you have the crank you can get some diamond pistons and l32 rods and you will have a very nice setup. I would recomend getting it all balanced if you buy everything seperate. I will be buying one as soon as i have the money.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 weeks ago
