How much lift can i have before i have to mill the valve guides?
Lift??
you were actually who i was looking for. i want to get 1.7 roller rockers too. how much milling and performance did you gain from them and your cam combination?96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
My SSM heads had the valve guides milled, so I didn't have to worry about it. I'm now running .538" @ 1.7.
Car feels very strong but I'm sure I need new injectors, as well as some tuning.
If you have the ZZP valvespring retainers, you'd probably be ok running that lift on otherwise stock heads.
[ March 08, 2005, 12:11 AM: Message edited by: 98Camaro3.8 ]Matt
1998 Mystic Teal Camaro M5
