i am looking into gettin a cam and was wondewring what specs would be best for nitrous and n/a? Also what gains would i see with this cam and how much would it be? thanks a lot
Best cam specs for both N/A and nitrous???
Past Ride
1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
(If you dont know me, you haven't had a V6 long enough)
Current Ride
2006 Mitsubishi Evolution GSR
www.myspace.com/shane1015Tags: None
210/214 .450/.450 113 l/s
Those are my cam specs, gained 25rwhp N/A and with a NX 100 shot put down 99 more rwhp for a total of 318 rwhp.
http://www.carolinafbodyclub.com/iro...oinfo4_jpg.htm
My cam is a reground stock one, (which is now small in the 3.8 world) I would go with a custom grind from Comp. You want more duration on the exhaust side for nitrous use. You should gain at least what I did from a Comp cam, go with more duration and lift and pick up a few more ponies.Michael Huff<br />92 RS, 98 V6, 97 SS, 00 Z28 <br /> <a href=\"http://www.carolinafbodyclub.com/\" target=\"_blank\">http://www.carolinafbodyclub.com/</a>
cool thanks for the info MikePast Ride
Current Ride
Those are great n/a gains but let me get tis straight, with the cam and a 100 shot you only gained 99 hp? shouldnt you have gained atleast that just from the nitrous?Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
I think he gained the 99 on the shot on top of the 25 hp gains N/A.
as far as the best cam for both you want something close to Ironmans thats a very good cam I was thinking something like
210/214 113 LSA 109 IC with maybe .507 lift........
maybe a little more duration but I'm sure that would make great power across the board.
How much nitrous you plan to use? If not over 150 I'd say keep it symmetrical.. and at least 212 durationKeith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
100 shot direct port is what im planningPast Ride
Current Ride
212/212 .525/.525 112lsa 110ic
how would that be for n/a and nitrous?Past Ride
Current Ride
I think that cam would do very well...
on a 100 shot of nitrous, don't really worry about cam specs.. it's not enough to warrant a change in spec really.. just make sure your exhaust flows good, like headers and a cutout and that should be all you need.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
<blockquote>quote:</font><hr>Originally posted by SLOWBRAEATER:
Those are great n/a gains but let me get tis straight, with the cam and a 100 shot you only gained 99 hp? shouldnt you have gained atleast that just from the nitrous?<hr></blockquote>
25 hp gain from the cam, which put me at 220rwhp. Then I sprayed the 100 shot and ended up with 319 rwhp.Michael Huff<br />92 RS, 98 V6, 97 SS, 00 Z28 <br /> <a href=\"http://www.carolinafbodyclub.com/\" target=\"_blank\">http://www.carolinafbodyclub.com/</a>
thanks Keith....yea i got full 3 inch exhaust with a cutout so it should do well.Past Ride
Current Ride
