what is the "clearance volume" (combustion chamber volume when piston is at Top dead center) of a stock 3.8 L36?
what is the clearance volume of a stock 3.8 L36?
2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhardTags: None
At TDC, my pistons stick up about .015" above the block deck
the head gasket is .067" so you do the math.1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
63ccwww.turbov6camaro.com
1997 3800 Series II Camaro
Originally posted by viper04af:
63ccMatt
1998 Mystic Teal Camaro M5
a cording to INTENSE RACING the stock heads or 63cc and after they port them they are 64....
thata were i got my info any waywww.turbov6camaro.com
a cording to INTENSE RACING the stock heads or 63cc and after they port them they are 64....Matt
THis would be easy to figure out if someone knew the dish volume of stock pistons. My diamond pistons have a 3.6cc dish.
I don't have the precision equipment to measure the dish of my junk stock pistons. I am willing to bet it is between 3.7cc and 4.0cc though.1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
Enter desktop dyno...
Head chamber volume 63cc
Head gasket bore 3.8"
head gasket thickness .067"
Head gasket volume 12.45"
Piston downbore @ TDC -.020"
Deck volume @ TDC -3.72cc
Piston dish.. 3.6cc?
Compression ratio 9.39:1
total combustion volume 75.33cc
swept cylinder volume 631.88CC
I got this from the #'s that everyone else gave me. It is ballpark, but I think it is pretty close.1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
