I was thining of switching out my 3.8 motor with a 89 Vette motor and a 700R4(if i have to). Has anyone attempted this before or is this alittle off the wall. The vette motor has just been replaced and i hate to just let it sit there. What woudl i all need??? What could i do for a wiring harness and guages? I realize this is probably a dumb, difficult question but its just an idea..any help is appreciated. thanks
97 3.8----> 89 TPI (possible???) Bad idea??
I normally hate it when someone does this but... why put the money into a 245 hp motor?
http://www.fast-autos.net/chevrolet/...tcorvette.html
It is your money so more power to ya, I guess it would be neat to see! But you would be better looking at the LS1 for a V8.95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
I'm pretty sure he's looking into the 50 billion boltons available out there that will let it make signifacantly more than 245hp
[ May 02, 2004, 07:56 PM: Message edited by: 3.4 slow to go ]1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
well this motor was running in the high 13s in the vette..I think it would be cheaper than modding my V6...and there ARE a ton of bolt ons...the motor that replaced this hits high 11s N/A and can easily run on the street (total bill was less than $5,000)...more or less I was wondering if I could use it cuz i have it and its costly to get an LT1 or LS1..no emission checks around here97 RS,3.73 LSD,Flowmaster,Shift Kit,Edge TC,HP Tuners,EWP,SLP CAI,160*,Touchscreen monitor,& Alpine Stereo(155.2dB)15.27 N/A 1.9X 60\'s and a magic switch.
Usually people put new motors in old cars, not old motors in new cars.
From now on we shall call you the "Time Traveler"1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
well man the biggest problem you will likely have is firewall clearance issues and issues with that distributor being in the back of the motor, it's going to wind up coming from under the windshield. As far as odb1 vs odb2 I'd just get a standalone accel PCM for the L98. if you can overcome the hood clearance issues, and maybe start off with a LS1 crossmember and modify it you could proably make the whole thing work, just gonna need some custom motor mounts and proably quite a bit of custom fab, with a cutting torch, welder and big *** hammer. I think it's one of those, with enough time and money you can do anything kinda problems.-Brad
2000 V-Star Custom 1100
:rock:
You can get by the distribuor issue by using a crap top distributor, or another lower clearance alternative. Personally if I was going to go through the trouble of swaping in a V8 I'd go ahead and get an LS-1 or and LT-1.2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
