Some Problems with my Jet module - FirebirdV6.com/CamaroV6.com Message Board
  • Some Problems with my Jet module
    ok its part # 68003 its some sorta module that came with my car when i bought it, but everytime i turned it on it just threw a map code so i left it off and just left it in the car...now the other day i went to take it out so i just cut the 5 wires and thought i was done...well i was scanning my car today and saw my map sensor was reading steady with no fluxuation...in the end i hooked the jet thing back up and all was fine again BUT I DONT WANT THIS THING IN MY CAR! lol has anyone run across this or have an install sheet they can email me a pic or copy of so i can back engineer the best way to take this thing out...obviously its on some kind of internal loop with the map sensor....its just a big hoobajoop of wires under my dash and dont feel like going any deeper then i have to but would like to get this done night.
    Thanks Guys,
    Bill
    00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
    see my responce on hptuners board (missing2)
      yah i responded over there...i got it semi figured out...as stated its a loop of some sort, two of the 5 wires had to be tied together for the map to work...i have to make sure the maf is working ok now but all looks ok so far.
        hrmm.. be carefull you may want to get out a wire diagram and check all of your work..
          im waiting for a fax from jet actually
