Need help on GN 3.8 - FirebirdV6.com/CamaroV6.com Message Board
Need help on GN 3.8
  • Need help on GN 3.8
    http://www.gmhightechperformance.com...9gmhtp_byebye/
    But i cant find the info on the swap....?!?!? can someone help?
    New:04 GMC Sierra 1500 RCLB 4x4 5.3 GU80 3.73\'s.<br />Truck pics<br />Mods<br />Go fast: Panel K&N filter and soon SS truck catback.<br />Appearance: Stull Billet grill,Weston Chrome step tubes,Rhino Chrome hitch step,ARE painted fiberglass cover,Silver star lighting.
    Oh Man! Would I LOVE to stuff a GN engine under my hood!! The pic of it shows that there isn't much room for anything else to fit under the hood except a few dust particles. That's sweeeet!
    -Marc
      <blockquote>quote:</font><hr>Originally posted by 94TeaL:
      <hr></blockquote> Try getting a hold of Steve Kaminski, he sounds like the man with the plan. Write a letter to GM High Performance and see if they have his contact info. Sorry that's all I can come up with.
        I just found this
        Can I swap a Buick 3.8L Turbocharged engine into my F-body?
        A: Steve Kaminski Turbo High Performance (Dept. CC, 2 Derby Dr., Sewell NJ 08080, 609/881-3235) does engine conversions of Buick V-6s into third generation F-cars. Some engine components used in the limited production 20th-anniversary turbo Trans Am (TA) are different than those used in the original (and far more common) Buick Grand National (GN). These revisions were needed to fit the turbo Buick into the third generation F-cars narrower engine bay.
        The TA turbo engine's cylinder heads are from the '86 Buick FWD Le Sabre (PN 25536701, casting no. 22536702). This head design uses individual stud mounted rockers in place of the original Buick V-6's shaft mounted rocker arms, so virtually every vauletrain part from the pushrods on up won't interchange. However, becuase this head and similarly designed siblings were common in FWD applications, GM still stocks most parts, and they are not that hard to find in the salvage yard. The TA short-blocks use different pistons to compensate for the Le Sabre heads' smaller combustion chamber volume; standard GM pistons would bump the compression from about 8.0:1 to 9.0:1--acceptabe on premium pump gas at stock boost levels.
        Turbo TA's require different exhaust manifolds (PN 25536214, right hand, discontinued; 25536215, left hand) than GN engines. With one side discontinued, custom headers are needed.
        Original GN heads fit the F-car engine bay by deleting the A/C system-but custom headers are still needed. Retain proper serpentine belt operation with a Chevy V-8/90-degree V-6 belt idler pully (PN 10055890) that bolts in place of the GM R-4 radial A/C compressor. Replace the A/C evaporator, heater core, and evaporatior covers with the non-A/C heater core, heater core box, and related accessories (part numbers vary by year).
        Although the GN TH200-R4 interfaces with the existing TH700-R4 shifter and shifter cable, installation of the Buick trans in an F-car requires the unique turbo TA trans support crossmember (PN 12396766) with cushions (547704, lowe; 547702 upper; three each required). The existing V-8 rear suspension torque arm interfaces with the standard F-cars trans mount (PN 17989705) and the turbo V-6 trans support crossmember via special brackets (PN 12396758 , outer; 12396756, inner). The trans support crossmember and torque arm are no longer availabe from GM.
        Alternativly, mate the Chevy V-8 TH700-R4 trans case to the Buick/Olds/Pontiac engine block using TCI Automotive (Dept. CC, 1 Equion Blvd., Ashland, MS 38603, 601/224-8972) adapter plate (TCI PN 230001)--the existing trans crossmember and torque arm brackets bolt up with no additional mods. The Buick computer can control the 700 trans, but the Chevy computer won't run the Buick engine. The 700 is stronger than the TH200-R4 and Kaminski claims the turbo engines run quicker with the Chevy trans.
        Kaminski offers stronger, thicker engine mounting barckets in place of the now discontinued GM items. The rubber/metal engine mounts that bolt up to the frame are still available from GM (PN 2213326, two required). The accelerator control cable is the same as used on the Chevy TPI V-8 F-cars (PN 14080202), but the TV cable (PN 25532115) and the cruise-control servo cable (PN 25525358) are specific to the turbo Buick-all cables are still available.
        The existing V-8 radiator works. GN radiators had an internal engine oil cooler, but the TA used a cooler similar to the Camaro/Firebird V-8 sandwhich style cooler. On the Buick, the cooler and a special adapter were sandwhiched between the Buick oil filter and the oil pump cover. Key parts for a Buick system are not available-go with a universal aftermarket cooler.
        You can still get the ECM module (its the same as the turbo GN, PN 1227148), turbo TA Engine/ECM harness (PN 12069323), and EPROM calibrator (part numbers vary-see your dealer)
          I just found this
          <hr></blockquote>
          It looks like you can, but the LT-1 would be much easier and less expensive
            But not as creative, and neat.... how many people have lt1 birds? Now how many have a turbo Gn motor in there fbody? ;)
              But not as creative, and neat.... how many people have lt1 birds? Now how many have a turbo Gn motor in there fbody? ;) <hr></blockquote>
              Let see with the TTA plus bye bye bird and soon you, that'll be 1557.
              This is the phone # to Kamisky's shop. Give it buzz and then let us know how it went.
              (610)622-4606
              [img]graemlins/thumbsup.gif[/img]
                <blockquote>quote:</font><hr>Originally posted by Mighty Thor:
                (610)622-4606
                <hr></blockquote>
                Are you saying he wont help with anything like ideas or anything?
