Got the maft+ in you got any settings i should try - FirebirdV6.com/CamaroV6.com Message Board
  • Got the maft+ in you got any settings i should try
    Right now i am useing -2% at WOT and +4 degrees in timing anyone else out there that has used this device with stock heads and cam got some settings worth trying
    <b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
    Do not link to there please.
    Scott
    [ August 31, 2002: Message edited by: Magnus ]</p>
      Scott, Please do not link to that forum. I am batteling myths spread there in e-mails on a daily basis now. It gets rather frustrating.
      Secondly, I disagree with that method.
      Please please whatever you do don't adjust you base settings UNLESS you modify your MAF setup and/or Injectors.
      By modifying the base setting of the MAF sensor, the error % is multipled at WOT. Your readings will be less consistant as well due to this.
      People on LS1tech like to tune based on LTrims.. But many people don't know WHY they are doing that.. they just do it.
      Here is how LT's affect our 3.8's
      Posivite LT's cause:
      Decreased trans line pressure (softer shifts)
      Sooner shifts
      Less timing advance
      Negative LT's cause:
      Increasd trans line pressure (Firmer shifts)
      Later shifts
      More timing advance
      Tune the car for WOT only unless you have driveability issues and must modify the base settings.
        Keith, read that link. What you described about the Negative LT's is exactly what is on the link.
        Scott
          Scott... we're talking extremes here.. +15% to -15%...
          Not +2% to -2%
          Unless your car has driveability issues, leave the base at zero. If you change the base settings, for whatever reason.. Why are you doing so? Why?
          So you can have 0% LT's at WOT.... Why? Why do YOU want 0% LT's at WOT instead of +10 or -10%?
          Let the MAF sensor do its job. The PCM relies on accurate MAF readings to determine the accurate LT's to give you a CONSISTANT air/fuel ratio. When you modify the MAF readings by a straight percentage, you adjust an entire curve by a linear value.
          Unless you have driveabliltiy issues, leave the base at zero.
          And let me ask you this Scott, do you think he knew how the + and - LT's affected our performance? I doubt it. Did you know the LS1 is almost opposite?
            This does not regard my car. I was simply relaying helpful information to a board member. If that is a problem please let me know. Thanks.
            Scott
