my buddy tld me that the GT cam would be to lowa duration, i should go more agressive and def put some rocker arms in there to allow or more air to enter for the longer duration.
higher than 220 duration with 1.8 rockers??
SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.Tags: None
you going NA/NOS/SC/turbo???
ans 220 on what side?www.turbov6camaro.com
1997 3800 Series II Camaro
you can't add much more duration without first getting comprehensive tuning. adding a lot of lift (by changing rocker ratio) to our stock heads will cause you some problems too; you will need to mill your pedestals / add better valve seals / replace stock with modified retainers.
that is a very basic rundown though; you will want to talk to somebody with more specific knowledge.
[ May 10, 2004, 09:21 PM: Message edited by: RallyRed 98 ]
stock heads no more then .500 lift
duration just takes tunning for the car to run without stalling or hoging gas like a 4 barrle 555 lolwww.turbov6camaro.com
Originally posted by viper04af:
stock heads no more then .500 liftMatt
1998 Mystic Teal Camaro M5
so if i got an aggressiv cam being higher than 220 with everything else stock, would my engine be straight?SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
There's more to a cam than just duration. Lift, Lobe Seperation, and more are equally as important. An aggressive cam may well go beyond the limits of an otherwise stock engine. We can't tell you how a cam will act while just knowing that it's duration is > 220.
http://users.spec.net/home/emxjc/cam_shaft_power.htmlMatt
.525 is supposed to be the limit on stock heads, after that milling is required. I know Matt (One QuickV6) has his cam on stock heads with .528 lift. I really wouldn't suggest running any cam without at least having some minor headwork done.2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
I dont think the added lift from 1.8 rockers is going to net you much more power. Its only going to give you problems. I would stick with the 1.6 stock rockers and try 220 duration if you want. You can still run high lifts with stock rockers, if you run high lifts with 1.8 rockers i think you will have problems. 1.8 Rockers are expensive anyways. Save your money.
