What kind of rods come stock? - FirebirdV6.com/CamaroV6.com Message Board
  • What kind of rods come stock?
    anyone know what kind of rods come stock in a 3800 series 2 for a 2000 Firebird?
    \"Knowledge is Power\"<br />There\'s no Replacement for Displacment.<p>Pro 5.0 Short Shifter, RK Sport Dual Exhaust, Fast Toys Cold Air Intake, Hotchkis Strut Tower Brace, K&N Air Filter
    the type that connect the crank to the pistons
    but seriously what do you mean by "type"?
    -Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
      are they cast, forged?
        "As market conditions have required higher horsepower's Chevy has responded by increasing displacement and in 1996 Chevy started producing the 3.8L (231 cid) engine being used previously by Buick, Pontiac and Oldsmobile. Production V6/90 deg. engines use lightweight cast iron blocks, two bolt main bearing caps, nodular cast iron crankshafts and forged connecting rods."
        Technical Database - Engine http://engine.firebirdv6.com/V690.html
        1997 Nassau Blue Vette<br />1989 Jeep Cherokee 4x4 (lifted with 31\" tires)<br />2000 V6 Camaro, loud, cammed 210rwhp *SOLD*
          Hmm.. I thought L36 had cast where as L67 has forged..
          Tech database may need to be updated.
            <blockquote>quote:</font><hr>Originally posted by chris2000v6:
            anyone know what kind of rods come stock in a 3800 series 2 ?<hr></blockquote>Um, stock rods maybe? :D
            <b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
              One of the two needs to be corrected:
              Key features of the 3800 Series II:
              "Lightweight pistons with floating pins and low-tension rings in combination with shorter cast-steel connecting rods reduce reciprocating mass and internal friction."
              Technical Database - Engine 3800 History http://engine.firebirdv6.com/3800history.html
