Injectors - FirebirdV6.com/CamaroV6.com Message Board
Injectors
  • Injectors
    What are some good high flow injectors for 3800 series 2 2000 firebird?
    \"Knowledge is Power\"<br />There\'s no Replacement for Displacment.<p>Pro 5.0 Short Shifter, RK Sport Dual Exhaust, Fast Toys Cold Air Intake, Hotchkis Strut Tower Brace, K&N Air Filter
    Before you ask a simple undetailed question, try using the search tool located at the upper right corner. Try something crazy and search for "injector".
    To answer your question though, the ones that are in your car already. Since you didn't tell us what you have done to your car then we can assume that it's nothing than hasn't been done on stock injectors so there's no need to upgrade.
    1997 Nassau Blue Vette<br />1989 Jeep Cherokee 4x4 (lifted with 31\" tires)<br />2000 V6 Camaro, loud, cammed 210rwhp *SOLD*
      you won't need them for a while, not untill all bolt-on's are done as well as heads/cam.
        sorry about that, was short one time, i have a spare block that im building up, sparing no expense, trying to decide between a super, turbo, or N2O, for the boost yet, but getting pretty much the whole nine yards, just wanted to know what kind of injectors would be needed for the three?
          a blown, turbo'd, 3.8 on the bottle, either you know something none of us know or you're dreaming up some CRAZY [img]graemlins/bs.gif[/img]
            i'd suggest either 42.5 lb. injectors or 50 lb injectors. both sets are able to support up around 550-600 crank hp.
              50's don't have great idle characteristics. A set of Lucas 009 (they're 42.5#ers) will do fine, have better driveability, plus they're plentiful (used sets run about $200 for a set of 6). I took a set of 009s into the 11.40 range using a single Walbro 340M pump at 27 psi boost before moving upward to 55#ers (I've since moved to 72's.) What HP level are you trying to attain?
              Morgan
              \'87 Grand National (11.08 @ 120, stock motor & heads with 159K miles and bolt ons only. UPDATE: New motor 09/01/03-- ported irons, 212/212 cam, T66 turbo, 72# inj, big front mount I/C) <br />\'99 Regal GS supercharged (14.001 @ 99 on the OEM Good\"rock\" LSs) <br />\'96 Roadmaster Limited LT-1 with some of the more popular Impala SS mods; my stealth Impala SS.
                I'd also recommend the Lucas 009 injectors. They're the ones I picked up for my engine. They are an extremely nice injector, and they support aprox. 550 hp at the flywheel.
                You want to know what\'s on my car? Tough luck!
                  Do you have to get injectors if your rebuilding your engine? If so , what would be the best injectors for my 3.4L and where can I find them for a good price? thanks
                  2002 Grand Prix GTP- FWI Intake , flowmaster 40\'s ,3.4 pulley , and Intense racing PCM.<br />94 3.4L camaro -Lots of mods!
                    <blockquote>quote:</font><hr>Originally posted by Ryan94V6:
                    Do you have to get injectors if your rebuilding your engine? If so , what would be the best injectors for my 3.4L and where can I find them for a good price? thanks<hr></blockquote>
                    New injectors are not mandatory for an engine rebuild.
                      <blockquote>quote:</font><hr>Originally posted by viper98885:
                      <hr></blockquote>
                      Thanks alot Josh.
                      [ April 10, 2003: Message edited by: Ryan94V6 ]</p>
                        Go with the nitrous, get a wet kit or a direct port, and a good fuel pump. Scrap the injectors.
                        1997 Dodge Viper GTS
