Here's a problem I'm suffering from on a 2kbird, 3800: Every once in a while, I'll go to hit the key to start it, and nothing happens. The security light stays on, but no trouble codes. I'll remove the fuse for the PCM for a few seconds, replace it, and it starts right up. Been thru the manual troubleshooting, and the best I can figure is that it's a bad shock sensor. Anyone?
Intermittent No-Start Problem
5 speed?www.turbov6camaro.com
1997 3800 Series II Camaro
ello?www.turbov6camaro.com
It is your VATS (Vehicle Anti-Theft System) acting up.
There could be a couple reasons why this is doing it. Could be the little chip on your key or it could be two wires loose or worn in your steering column. Try searching here for "VATS" or for "Security Light" you will recieve tons of info on this. [img]smile.gif[/img]
or it may not be your VATS. could be your neutral safety switch. If its stick, check that first. its behind the clutch pedal under the dash, mounted near the firewall. its like $8 to replace, but to check it, unplug it, and use a "U" shaped piece of wire and put the wire in the plug, so it completes the circuit. MAKE SURE THE CLUTCH IS IN, and try to start the car. If this works, just go replace the switch.
REMEMBER, IF YOU BYPASS THE SWITCH, YOUR CAR WILL START W/O THE CLUTCH BEING IN!
that y i was asking if i was a 5 speedwww.turbov6camaro.com
Originally posted by Ian:
or it may not be your VATS. could be your neutral safety switch. If its stick, check that first. its behind the clutch pedal under the dash, mounted near the firewall. its like $8 to replace, but to check it, unplug it, and use a "U" shaped piece of wire and put the wire in the plug, so it completes the circuit. MAKE SURE THE CLUTCH IS IN, and try to start the car. If this works, just go replace the switch.Matt
1998 Mystic Teal Camaro M5
I had that same problem for a long time, because i used my key to pry something open and it was slightly bent. I started using my spare key and havn't had a problem since.-Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open Downpipe
Originally posted by asdf1234:
I had that same problem for a long time, because i used my key to pry something open and it was slightly bent. I started using my spare key and havn't had a problem since.www.turbov6camaro.com
If your car still doesn't start refer to my post under general tech bypass security
http://www.camarov6.com/ubb/ultimate...c;f=1;t=013081
I will never have that problem again. I just went around it. And yes you still need a key to start the car, just in case any would be thiefs are out there.
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...18 hours ago
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....5 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.5 days ago
