I have just recently changed my gears out and stuff and need to get my pcm reflashed. i found a place to do it . i have heard of people using a 2000 vin to replace their 99 vin so they can use hypertech. I was wanting to do this. I am asking if there is anyway i can borrow two things just for reassurance. I need to borrow a 2000 vin with the y87 package on it and also a 99 with the y87 package on it. this is just incase the 2000 vin doont work. i have an automatic with 3.42 gears and lsd. i appreciate anyone that can let me borrow theirs. Thanks.
My car was a 99 with an open 3.08 rear. I installed 3.42s and LSD and flashed my PCM with a 00 Y87 VIN to correct the speedo and shift points. I believe that I still have the VIN I used at my house. If not I can call someone and get it for you. [img]smile.gif[/img]
I have 3.42 gears but not Y87.. I had an open diff and 3.42's
2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
I have to go out to my car and get it.... I'll post it after lunch.. [img]tongue.gif[/img]
2G2FS22K1Y2157582... There you go.. If you were leaving it up to a Texan you'd still be waiting.... :D ... [img]tongue.gif[/img]
Originally posted by Georghino: </font><blockquote>quote:</font><hr />My car was a 99 with an open 3.08 rear. I installed 3.42s and LSD and flashed my PCM with a 00 Y87 VIN to correct the speedo and shift points.
I saw somebody somewhere in this forum saying that by flashing the PCM you only fix the speedo but not the shift points. is that true? </font>[/QUOTE]No truth to that whatsoever.
Another example of people on this board portraying incorrect information as correct. [img]smile.gif[/img]
That VIN given above is for a 2000 Firebird. I am like 99.9% sure that doesn't matter at it will work fine on a Camaro. Could someone confirm?
Thanks!
IN:
2G2FS22K1Y2157582
Year/Make/Model:
2000 PONTIAC FIREBIRD
Body Style: Hatchback 2 DR
Engine Type: 3.8L V6 MFI
Manufactured In: CANADA
I had some 3.42's and a LSD put in my car and now my car is just plain slow. I got Wester's programming for shift points and speedo recalibration. I thought that would help it and it did help somewhat but not nothing like I thought. I can't even really explain it, it sounds like the car is making a lot of power but it just won't go. Like the computer is holding back power or something. Hard to explain unless you are driving it. Defintely slower than when I had stock 3.08's and open diffy. Anyway, Wester's is sending me another PCM and if that doesn't fix it I will try having my PCM flashed with a 3.42 program.
