206 / 212 at .050"
Intake lift .320" (.512" lift at valve with 1.6:1 rocker ratio)
Exhaust lift .325"(.520" lift at valve with 1.6:1 rocker ratio)
Lobe separation 113
What yall think i am gonna order on fri probably
<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
<blockquote>quote:</font><hr>Originally posted by Magnus: I'm pretty sure COMP Cams are on backorder... EVERYBODY at clubgp things so.. Nobody can get a cam through COMP right now for the 3.8 series II..
Yea that grind is recomended to everybody. Should be a decent daily driver cam.<hr></blockquote>
I called comp directly last week. They told me they have 10 cores. I ordered my cam and they said it will be to my house in 2-3 weeks. I have also heard that comp is out of cores but when I called comp directly they told me they have cores left.
<blockquote>quote:</font><hr>Originally posted by Ironman24: 3.8's don't use a rocker stud, they have a bolt that should be replaced any time you remove it. They are about .75 a piece from GM. <hr></blockquote>
Interesting. I didn't know that.
94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
