ZZP's site says that the stock heads flow worse over 0.500" lift as I also thought, but their VS cam for stock heads has the specs:
206/216 at .050"
Intake Lift .320" (.512" lift at 1.6:1 rocker ratio)
Exhaust Lift .317" (.507" lift at 1.6:1 rocker ratio)
115 Lobe Separation
Why would they go over 0.500" lift if this is for stock heads? Also, is this a good cam for a 3.8 with an intake/3" exhaust/highflow cat/pacesetter headers/stock shift points or would a custom one be better?
206/216 at .050"
115 Lobe Separation
