well i have a 98 3.8 with a supercharger and would like to put a new chip or have my stock one reprogrammed since they dont make any tuners for a 98 does anyone have any opinions on where to go.
Chiped
Originally posted by blackFbird_98:
since they dont make any tuners for a 98 doesMatt
1998 Mystic Teal Camaro M5
which tuners work I have looked into Hypertech and didnt think they worked but even if they did I wouldnt use Hypertech since they suck, and the one from Crane well a couple of months ago they didnt have anything neither<a href=\"http://www.cardomain.com/profile/blackfbird_98\" target=\"_blank\">http://www.cardomain.com/profile/blackfbird_98</a>
I'd get it dyno tuned if I were you. Fast Chip in Tulsa, OK does a great job of it. I have their number here somewhere.
FastChip
1141 W. 41st.
Tulsa, Oklahoma2001 V6 Camaro - VTEC Badged, Abbott Racing Heads Sticker, and Loud A$$ Exhaust<br /><br /><b>BUILT NOT BOUGHT</b><br /><br />14.0 @ 96.44 MPH (Street Tires, Before Tranny)<br /><br /> <a href=\"http://members.cardomain.com/6pakcamaro54\" target=\"_blank\">http://members.cardomain.com/6pakcamaro54</a>
Chips are a waste of money. Get a tuner (DHP or HP Tuners) and do it yourself.Matt
There are no "Chips" for our cars. Here are your choices.
1. Hand Held Programmers. These devices are plugged into your ODB II port and modify your PCM (like the Hypertech) but they are only a little effective and only on a slightly modified car. You would never want to use one of those on a car with a bolt on SC.
2. Mail order tune. Next you have mail order tunes. These are good if you are not able to get a dyno tune or you do not have the knowledge to tune the car yourself. However, you will not get the most out of your car with a mail order tune.
3. Dyno tune. This will probably give you the most gains. It will give you the most horsepower with the best safety factor. The main drawback is if you do any other mods, you will have to go back if you want to see gains from that mod. That can get expensive.
4. Do it yourself programmer. There are two on the market for our cars, HP Tuners and DHP. These give you the ability to change hundreds of parameters in your PCM. This is the most flexible solution and if you are willing to put in LOTS of hours, it can be as effective as a dyno tune.
Hope that helps. Good luck.2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
The only downside to a dyno tune is drivability. Most dyno tunes concentrate on WOT performance, but street driving is usually part-throttle.
I say the best thing to do is buy a DIY tuner, and rent a few hours on a local dyno or dragstrip to get your WOT tuning done.
- Justin<a href=\"http://www.njfboa.org\" target=\"_blank\">New Jersey F-Body Owners Association</a><br />1987 Camaro LT - 400sbc, Aluminum L98\'s w/valve job, Comp XE 274, Q-Junk 750, 3.23 posi, 4.10\'s soon.<br /><br /><a href=\"http://www.njfboa.org/forums/viewforum.php?f=11\" target=\"_blank\">East Coast F-Body Nationals - August 14, 2005</a>
