My knock retard problem.. My heads/cam V6 is slower than stock. - FirebirdV6.com/CamaroV6.com Message Board
  • #46
    In case anyone is interested.
    This month, Muscle Mustangs and Fast Fords Magazine has a descriptive article on testing piston/valve clearance when selecting/changing the heads/cam on a 5.0 Liter.
    Granted, the test should work the same on our 3.8L.
    This is simply an interesting article to read.
    Dave
    • #47
      <blockquote>quote:</font><hr>Originally posted by black98V6:
      4.10's.. [img]graemlins/omg.gif[/img] DAYUM dude!.. if you are spraying out of the hole you might pull the whole front end with that.. go for it man! [img]graemlins/thumbsup.gif[/img]
      [ September 20, 2002: Message edited by: black98V6 ]
      <hr></blockquote>
      But, It wouldnt be the first time. He says he pulled 1 tire.
      • #48
        LOL, when I was going to put nitrous on with my 4.11s, everyone said it's a horrible idea, and to never do it. But now everyone's going to say how good of an idea it is...
        Anyway, I'm getting ready to replace my heads with ported heads, raise my compression to 10.4:1, put in a 212/216 .50"/.50" 112 cam, ported intakes, tb spacer, and high flow cat, I'm looking to work on you top NA guys when it cools down.
        Goodluck racing this fall with the fixed car Magnus.
        2001 A4 Pewter 75th Anniversary W68 Firebird<br />1997 Dodge Ram Extended Cab 360 CID<br />1996 Ford Explorer V6<br /><i><b>Any number you can think of, I can think of one higher.</b></i><br /><a href=\"http://www.criesmusic.com\" target=\"_blank\">www.criesmusic.com</a><br /><a href=\"http://www.mp3.com/beneaththestage\" target=\"_blank\">www.mp3.com/beneaththestage</a><br /><a href=\"http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar6.jpg\" target=\"_blank\">http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar6.jpg</a><br /><a href=\"http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar4.jpg\" target=\"_blank\">http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar4.jpg</a><br />AIM: Guitarchitect201
        • #49
          I replaced all the lifters.. Valvetrain is a LOT quieter now.. sounds good.
          Knock retard remains. I repeat, knock retard remains. :(
          At WOT the sensors pick up nothing! Just at low RPM's.. so perhaps its just picking up cam misfires through the headers.
          Just to refresh. I get a FULL 15 degrees of retard instantly any time I punch it from low rpm's.. I get ful 15 when I cruse at low RPM's.. and the knock count just goes up like 50 knocks a second.
          So.. the sensors are cunrrently unplugged. *sigh*.
          Also Epic, CamaroZach and I went racing.. whacked some import with a hot chick in the pass seat. Then just Zach and I went out racing and met up with Bird OF Prey.. street racing is always so much drama.. too much talking not enough racing (On private property obviousely).
          Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
          • #50
            I don't understand what happens when you unplug your knock sensors. Does the computer not retard the timing then since the sensors are unplugged? How is your car running when they are unplugged? What is the problem with leaving them unplugged?
            1997 Supercharged Firebird<br />14.01@99.7mph 2.1 60ft.
            • #51
              With the sensors unplugged the car doesn't add as much timing as it would with them in there.. I probably miss out on 4 degrees or so..
              But from low RPM flash I miss out a lot.. The PCM just doesn't add that much in there to be safe.
              The car launched much harder with good working functioning knock sensors.
              What I might try is grounding out the sensors with a resistor.
              • #52
                Does this mean that all v6 with the powerpack will have these same issues?
                Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
