Update on the car. Car is running and its fixed. - FirebirdV6.com/CamaroV6.com Message Board
  • Update on the car. Car is running and its fixed.
    I had a blow a head gasket. So my oil pretty much turned to milk. Not very pretty so i changed all my gaskets from the crappy Stock GM gaskets to all fel-pros. God they are a much better gaskets. Well we started it and man it should good right now. I will post up a new video soon cause it sounds so much better than before. There is a very desinct lobe now. I love my car. I also got all the KR out of my car. I went from 14.9 degrees of KR down to 0 my car runs like a champ now.
    <b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
    awesome :D
      kris.. you da man... i have a new cam coming very soon [img]graemlins/evilgrin.gif[/img]
        Kris thats great to hear. I was dissapointed when I heard you were having troubles. ANd it seems you fixed it in a timely fashion. Good job.
        I have also heard the stock 3.8 Head gaskets can cause KR because the gaskets suck so bad part of it hangs into the chamber.
          had a ride in the beast last night
          man does it pull like a beast deffenity gonna need much higher shift points.
            Yes it does it really needs to shift at 6300 rpms and it really needs a 4000 stall converter. LOL
              how would it be with a 5 speed with 3.42s?
              would it be a nice cam?
              96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
                that's awesome kris, i have a 218/218 coming... and i right now my 1-2 is shifting at 6450 and my 2-3 is seeing 6100 [img]graemlins/evilgrin.gif[/img]
                  Chris I don't remember reading about a break-in for the camshaft, but I see you're posting 6,000+ RPM shifts. Please tell me you took the time to properly break the camshaft in?
                  <b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
                    he broke it in [img]smile.gif[/img]
                    the right way [img]smile.gif[/img]
                      being a hydraulic roller break in isnt as critical as it would be w/a regular hydraulic or flat tappet cam...
                      <b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
                        I held 2000 rpms for 20 mins for the inital break in
                          is this cam good for a 5speed?
                            I heard that with a hydraulic roller you dont have to do the 20 minute thing. A few older guys said just give it he**, if it breaks than the motor was put together wrong [img]smile.gif[/img]
                            Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
                              roller cams don't need to be broken in....
                                4 days ago
