Hey guys, I drove my mazda home from a friends tonight and when i got home and shut the radio off, I immediately noticed a loud clacking coming from the engine. It seemed way too loud to be a cam follower, but actually almost sounded like it was dieseling. Is this rod knock? Am I screwed up the *** right now? My camaro project is taking all my money and I don't have money to rebuild this engine...any ideas as to what this might be?
Loud knocking....
Loud knocking....
1994 Camaro: Firebird Interior, 3.4L to 3800 converted, OBD2 converted, A4 to M5 converted...In the turbo retirement home...<br /><br />1994 Mustang GT: 347 Forged Stroker, Port Matched Edelbrock Heads and Intakes, Tremec 3550 T-5, Spec Stage 2Tags: None
Where does it sound like it is comeing form?
Up high or down low?\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
get a wood dowl or 2x4 and put it on the motor in different spots and stick you ear up to it.... try vuavle cover first then move down the block you will be able to tell where its coming from
also before you start it again check the oil.....www.turbov6camaro.com
1997 3800 Series II Camaro
well, i added a little oil cuz i knew it could use it, started it up this morning, clacked for a few seconds then died out right away. It needs an oil change, but it seems to be ok now. Maybe it was just one of the lash adjusters but man, that was pretty loud....like, not loud loud, but in comparison to your usual valve tapping it was....thanks guys.1994 Camaro: Firebird Interior, 3.4L to 3800 converted, OBD2 converted, A4 to M5 converted...In the turbo retirement home...<br /><br />1994 Mustang GT: 347 Forged Stroker, Port Matched Edelbrock Heads and Intakes, Tremec 3550 T-5, Spec Stage 2
