ok guys check out my page, now out of all that i'm getting the fuel pump, cam, p&p of the heads,upping from a 75 to a 100 shot, 3.73 and the posi done this week. i raced my b/f's mustang gt yesterday and i had him on the start but then soon as i went into second i couldn't catch up. my car will just fall flat on her face. what can i do now?
falling on my face
you have all that stuff done or you are getting that done?
If you had that all done maybe you should get a tuner to tune for all the changes. Cam and heads pretty much need a good tune to maximize them.
What cam did/are you getting?
well I checked your site and noticed that you have HP tuners. So I guess you have that covered, maybe work on the tuning some more to work better with the mods.
Or maybe your nitrous bottle ran out...
Look for Knock Retard. That will kill your power every time. Use HP Tuners and see if it is KR.2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
Here is what you need to do. Log a "Run" with a few wide open throttle sections. Now save the scan and then open the log file. Bring up the histogram and click on the Knock Retard tab. Now right click on the table and choose "Max Value". If any values are over zero, you have KR.
What to do about it if you do is a whole other probelem. But for starters, just find out if you have it.2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
There are lots of things it could be but start with the most likely. Once you get a log, send it to me and I will check it out.
arthansen@cfl.rr.com
p.s. Bring that car down to Orlando...nothing I like better then getting my a$$ beat by a chick!
;)2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
did u put in larger injectors? I doubt the stock 22's are flowing enough with your upgrades.00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
hey guys i just found out today that i have been running very lean so hopefully the new injectors fix it! had to get the 42.5 ones they were my only option. since i had to get them next day delvi. since the car is going to be finished thusday afternoon. and why rip everything out again right! i'll let you guys know!
the injectors wont necessarily fix it. You need to tune the computer. Especially before you even attempt to spray it with the new injectors.<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
