i want to run an all motor setup. what would be the best cam to use? i will be ordering from www.lmperformance.com or www.ftpp.net . so my choices are limited to what they sell. also i might add a supercharger later on but not sure so the cam would have to work well with or without the charger. Please help! [img]graemlins/banana.gif[/img]
sorry i just really like that banana.
2001 Black Camaro<br /><br /><br />I have no clue how i beat you.....maybe your car is slow.<br /><br />Whisper lid, SSRA, Pacesetter Headers, Carsound 3\" Cat, SLP Loudmouth, BMR strut brace, black ZR-1 rims, Xenon kit
If you want a strong NA cam, then you will not get as much of a gain with a blower. A good cam for the supercharger will not give as good results NA. Also, if you really want a good cam, then you need to consider other vendors such as ZZP or Intense.
Originally posted by camarov62003: i want to run an all motor setup. what would be the best cam to use? i will be ordering from www.lmperformance.com or www.ftpp.net . so my choices are limited to what they sell. also i might add a supercharger later on but not sure so the cam would have to work well with or without the charger. Please help! [img]graemlins/banana.gif[/img]
Your best bet of the cams already there is the
COMP-CUSTOMGRIND1
from ftpp, but I believe they can get custom grinds there?
Lmperf doesn't sell cams for us that I know of?
If you want a good N/A and possibly blower cam:
To get the best of both worlds you're gonna want a split duration favoring the exhaust side, and a LSA of about 113-114 which is in between the 115 common blower LSA and 111-112 which is more for N/A.
Lift is lift it isn't THAT big of a facto do about .510 or so and you should be fine, the IC just advances or retards timing, so do some research on that because I'm not 100% sure which is better yet [img]smile.gif[/img]
Go to ZZP or Intense Racing to get a cam for a 3800.
2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
