The big Jump to a LT1 - FirebirdV6.com/CamaroV6.com Message Board
  • The big Jump to a LT1
    My car goes in the shop on Wednesday to get a Built LT1 motor dropped in I stumbled across a LT1 that has 22,000 miles on a fresh build up the heads were shaved it was cammed and roller/rockered one of the guys from my local track owns a shop and is throwing it in for $3200.00 includes everything i need minus the work to the rear end I.E ( LSD WITH 373 and full suspension package ) and a new bell housing
    1. any thoughts or suggestions on lsds or wich ones are reliable.
    2. I will have parts for sale from the old 3.8 let me know what you need and i will see if it is worth selling or not sold yet.
    the faster our cars go the slower they seem.
    go for the zexel
    much stronger than an auburn and no clutches to wear out...however if you get a take-out diff and use 4.10s or motive 3.73, you will need a two piece pin to seperate the axles or grind down the solid pin.
    1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
      Why a new bellhousing?
      1997 Dodge Viper GTS
        the bellhousing from a V/6 wont fit a LT1 but i may have found a fully built trans out of a 95 that is set up for 600HP if i can nrgotiate a good price.
          You don't want to put your v6 tranny on the Lt1 no matter what. Get the 6 speed.
          Unless its an auto, then nevermind.
            i went with the racing trans mentioned above it is set up for six hundred horses and the build sheet shows total cost at 1200 i am getting it for $900.00 and am sure i will be happy.
