Car won't start!! - FirebirdV6.com/CamaroV6.com Message Board
Car won't start!!
  • Car won't start!!
    Just finished doing head and cam package on my 94 3.4L. I had the car going on Sunday night. seemed to be working fine then the next day it wouldn't go. The car cranks over fine so it seems to be a fuel problem or maybe a ground(although I checked them all). Anyone have any suggestions?
    You'll need some more information than that! Tell us everything that's up, what you did, what you didn't do, what you replaced in the install. Cranks but no fuel? Got gas? Vacuum? Fittings? Leaks?
    -Rob
      Yes. The car is cranking over almost ready to start but just won't catch. I have gas. I installed a comp cam, 1.6 rockers,new springs,new timing chain, heads and intake ported and polished. I've checked all the grounds and cleaned them up and I have new plugs and wires. Like I said the car did start and ran fine Sunday night but hasn't since.
        put on some seriously heavy gloves.. and get someone to crank the engine.. hold your hands directly behind the exhaust pipe(s).. if you feal pulses of air moving around your hands.. and smell gas.. then it is probably not fuel..
        ~Billy
          Does your engine seem flooded? Can you smell the fuel vapor? If so, you may be in need of a new set of injectors.
          You can achieve anything for which you are prepared to pay the price.<br /> --ATTILA THE HUN
            1. what do the plugs look like now?
            2. what is the fuel pressure key on engine off, and while cranking? what should it be?
            3. are there any fuses inengine bay/under dash that might be blown?
            get coil paks/ecm tested, just in case.
            2013 Ram 1500 Big Horn
            94 comero 3.4
