How hard/involved is it to install new cam bearings??
Cam Bearings?
Cam Bearings?
Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....Tags: None
gotta take your whole block apart... fine if you're building from the ground up, but not anything you can do with the motor in the car. i think az3.8CAMaro did something where he replaced the front bearing and secured it with jb weld which apparently works in a pinch, but... i wouldn't want that to be the be all and end all of bearing replacement.
not only that if you dont get them in there perfect it will **** upwww.turbov6camaro.com
1997 3800 Series II Camaro
Don't mess with cam bearings unless your block is completely stripped.
Unless your name is magneto and you are from an x men comic book. Then it would be easy.1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
ok so i'll save the bearing until I rebuild the bottom part of the motorBen<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
You need a cam bearing puller/installer tool there about $70. And new cam bearings.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
