Well, auto tap is what I knew to call it but it is really a hand held scanner that can give me some numbers:
OK, at idle
-17-19 degrees timing
Idle 730-750 rpm's
Map sensor 9-10
OK, now these are WOT
Map sensor goes from 10 at idle to 30 WOT
What does that mean?
Timing
WOT low rpm is -21.5 degrees and then as it approaches a shift it is at -25
Again, any feedback?
O2 sensor 1 bank 1 read 895 to 920 millivolts
02 sensor 1 bank 2 read 920 to 940 millivolts
O2 sensor 2 bank 1 read 920 to 930 millivolts
O2 sensor 3 bank 1 read 870 to 885 millivolts
These were wot with me reading them as I was driving so numbers are really close to what I remember
Which is sensor 1, 2 and 3?
Banks 1 and 2?
Are those good numbers?
I have an afpr that I can play with.
I do not know what my current fuel psi is but I will find out tuesday.
I'm looking for some feedback on these numbers if someone could assist me.
I want to go faster and I always guessed with tuning.
Now I wanna tune
Thanks for any help
If you need more numbers I can get them
OK, at idle
Idle 730-750 rpm's
Map sensor 9-10
Timing
Banks 1 and 2?
Now I wanna tune
Thanks for any help
