Intake Centerline??? - FirebirdV6.com/CamaroV6.com Message Board
  • Intake Centerline???
    What is intake centerline?
    What does it do and what does it affect?
    I ordered my cam 212/212 520/520 112LS and 112Intake Centerline
    What will a 112 intake centerline do for this cam. Magnus I know you mentioned yours is 110, what difference will this make for my cam compared to yours?
    I never specified the intake centerline when I ordered the cam. Compcam's selected this intake centerline for me.
    112 LSA 110 IC means it's advanced 2 degrees.
      what about 112ls 112ic
        No advance. I learned that in chat over at the other site. See it's not so useless. Someone there knows about cams.
          Great info supersix, you beat me to it!
          Scott
            I'm surprized they recomended no advance. I highly recomend a new timing chain with your cam then.
            I ORDERED a cam with 2 degrees of advance, however on my cam card it shows a cam of 4 degrees of advance.. oh well..
            The reason I ordered only 2 degrees of advance is over time a timing chain will stretch.. 4 degrees worth, I doubt... so I figured 2 degrees would be the perfect medium.
              I did get a new timing chain, so im ok then?
                You should be fine. It will be interesting to see how our dyno graphs compare with just different intake centerlines.
