I'm installing a window switch for a nitrous kit and the switch requires you to tap into the brake light wire (I guess if you hit the brake pedal it dis-engages the nitrous) but I was wondering the best place to tap into for this....its a 2001 3.8l camaro. I went to http://engine.firebirdv6.com/38pin.html of this site and saw Pin #30 = TCC Brake switch on the pcm. Would that work?
