engine component compatibility - FirebirdV6.com/CamaroV6.com Message Board
  • engine component compatibility
    Curious about what 3.8l items are interchangable on Camaro/firebird/grandprix/bonneville/regal/lesabre
    I'm only sure about heads being interchangable
    Anyone know if these are interchangable:
    -Throttle bodies (at least the cast if the throttle cables hook up diffrently)
    -Lower Intake Manifolds-pretty sure these are
    -Upper Intake-only firbird with camaro and the rest with the rest
    -Cams - grand pix gt with camaro with firbird are compatible
    - what about lesabre/bonniville
    -rockers/pushrods/springs/lifters ??
    -Obviously the exhuast manifolds and trannies are different for the FWDs
    -What about the block, I have heard from a junkyard woth compatibility software that the FWD blocks differ from the RWD blocks, anyone else heard this
    1996 Silver Camaro, Y87, M5, cammed..<br />N/A Best Time: 14.012 @ 98.59<br />195 rwhp / 233 ft-lbs b/f heads/cam<br />Check out my site <a href=\"http://silver3800.cz28.com/\" target=\"_blank\">http://silver3800.cz28.com/</a>
    Pretty sure they are different. but not 100%
    I have heard there is a difference that makes them incompatible . I think the thermo is in the wrong spot.
    - what about lesabre/bonniville,
    Yes, almost positive.
    -same
    yes
    not sure
    not sure
    1997 GTP(13.3@104)-Sold<br />1999 Trans Am M6
      There is something done as well, with the lesabre, and I think bonneville, that GM factory rates them at 205 hp and 230 torque. I don't know for sure if it's intake manifold or exhaust manifold design, but GM claims 5 more horse and torque from them
      2011 Camaro LS 6M, in black.
