PUSHROD's 5/16 or 3/8??? - FirebirdV6.com/CamaroV6.com Message Board
  • PUSHROD's 5/16 or 3/8???
    Stock Pushrod's are 3/8 right? Will 5/16 work ok? What difference will this make? Its easier to find a 5/16 pushrod for the length I need. Can I just get 5/16?
    simple question need help.......TTT
      Maybe noone knows.
        most likely they are 5/16 and you wont be running enough spring pressure w/a hyrdaulic cam to need to put 3/8 unless you just want to...
          5/16 should be fine. Thats what I run.
          Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
            So 5/16 is the stock size? My mechanic told me to order 7 inch.
            Will these work then?
            http://store.summitracing.com/partdetail.asp?part=29898
              Those are the ones I have. [img]smile.gif[/img]
