i was planning on purchasing the powerpak but now im hearing all this about its not worth it and a cam swap would be just as effective. what do u guys suggest i do? powerpak or a cam and maybe a valvetrain rebuild?
supersix or straight up cam swap?
If you want all out NA performance you'll need a set of heads.
If you just want some more power at a more affordable price, than a cam only may be what you want.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
A cam without no headwork would be worthless to me , but thats my opinion. The supersix powerpack with heads/cam/intakes would definetly give you a more hp gain.2002 Grand Prix GTP- FWI Intake , flowmaster 40\'s ,3.4 pulley , and Intense racing PCM.<br />94 3.4L camaro -Lots of mods!
<blockquote>quote:</font><hr>Originally posted by slomaro:
hrmm 20-30hp easy with just a cam is worthless? for a little over 300 bucks
you dont know **** shut the **** up<hr></blockquote>
Now,lets not act out of hand here.If you read my post then you will see that it say that its "MY OPINION".2002 Grand Prix GTP- FWI Intake , flowmaster 40\'s ,3.4 pulley , and Intense racing PCM.<br />94 3.4L camaro -Lots of mods!
tell me what other mod besides a nitrous kit will give you 20-30 hp for 3-400 dollars
NOTHING not a thing hell a converter cost more money then a cam swap and most people dont understand how easy a cam swap is
actlly unless your gonna get a big ol cam with lift above .500 then then there is no reason really to get p&p heads if your just looking to pick up 20-30 hp not everyone wants a race car.
if you do a heads and cam install it will cost you over 1K easy
300 cam
150 spring
retainers
bolts and gaskets 150 - 200
p&p heads 200 or so if you do them your self and get a 3 angle valave job done on them or 800 if you dont wanna bother with heads
hrmmmm and if you put a big cam in you gotta get you pcm programed or its not really worth it and if you have an auto then a converter it adds up fast
a simple GT cam is good for at min 20 hp should put an auto even in the 200 rwhp range
hell ironman24 installed a pussy little reground cam and layed down 220 n/a rwhp with his manual so to say a cam is not worth it is BS iromans cam is a weak cam with not even .450 lift you can go to .500 on stock heads before it really tapers off
in that case, would getting the heads with the 3 angle valve job from supersix, not touch the manifolds and get a fairly larger cam from some other vendor be a decently good approach? or should i do it all thru TomSLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
300 cam
150 spring
retainers
hell ironman24 installed a pussy little reground cam and layed down 220 n/a rwhp with his manual so to say a cam is not worth it is BS iromans cam is a weak cam with not even .450 lift you can go to .500 on stock heads before it really tapers off<hr></blockquote>
Damn, I really didnt know that, ive alway thought on not too big cams .You can probly say I dont have the biggest cam in the world(powermax 2030 204/214 109 LSA .451/.451 lift with 1.6 gold series rockers) but hoping I can get some pretty good power out of it . I always guessed my cam would only produce 15 hp at most but what would you think?2002 Grand Prix GTP- FWI Intake , flowmaster 40\'s ,3.4 pulley , and Intense racing PCM.<br />94 3.4L camaro -Lots of mods!
where are you guys getting 300 for a cam? is that cam and install, or just cam, im looking into a cam and ammp has them for like $180, and the cheepest cam install i have found is like 500 so if that the 300 is for both, i want to see where you guys are getting your work done atFighting Texas Aggie class of 2008<br />black 3.4 T-top bird<br />- K&N CAI - magnaflo catback - slect coils - catco cat - tb coolant bypass
I didnt say anything about a cam being 300 dollars.Your cam is about a right price from what ive seen.Oh and 500 dollars is about right for a cam install.2002 Grand Prix GTP- FWI Intake , flowmaster 40\'s ,3.4 pulley , and Intense racing PCM.<br />94 3.4L camaro -Lots of mods!
<blockquote>quote:</font><hr>Originally posted by FuryCharger:
in that case, would getting the heads with the 3 angle valve job from supersix, not touch the manifolds and get a fairly larger cam from some other vendor be a decently good approach? or should i do it all thru Tom<hr></blockquote>
The way im going is not through Tom but dont get me wrong,Tom knows excactly what he's doing and what he talks about.Im going a much cheaper route to a mechanic I know that owns half of a machine shop and also knows excactly what he's doing .Im having my heads ported with a 3 angle valve job with my intakes ported and polished as the same with my throttle body , and he's also installing a cam. He's installing much more but its just a long list and I dont feel like typing it all out.2002 Grand Prix GTP- FWI Intake , flowmaster 40\'s ,3.4 pulley , and Intense racing PCM.<br />94 3.4L camaro -Lots of mods!
what cam can you put in and still pass emmissions test? i was thinking of just putting the intese 1.9 rocker arms on to increase the lift of the stock cam. but it is more expensive $350 than a cam but it is easier to install. what is better to do for power and emmissions i need to drive the car so i dont want to have any probs. thans.
ok, figure a good Tc for about 450, and install for about 400. a cam will usually require springs as well, so about 300 for a comp cam, and 150 for springs. plus u need gaskets for 150, and labor for about 400 as well. heads from super six are 500, plus about 200 for the intakes, and labor is about 200.
Totals:
TC: 850
Cam: 1000
Heads/Intakes: 900
cam will get u the most hp, heads will get u set for an even bigger cam in the future, and TC is off the subject, but somebody else mentioned it earlier.2001 Arctic White Firebird<br />More mods than I\'m allowed to list!
Couldn't you just buy part of the powerpack (heads/intake) and then buy a custom grind comp cam or something?? I'm not expert by any means, but I know there are some ssm heads for sale in the for sale section (there were a little while ago though, they could still be there) and then buy a nice custom cam? Is the question more of what's the best way to go for more N/A power with money as no object, or what is the best bang for the buck engine mod?AIM: Alientr8tr<br /><a href=\"http://www.cardomain.com/memberpage/583450\" target=\"_blank\">1998 Camaro 3.8L</a><br />Flowmaster 80-series, !FRA, Eibach Springs, KYB AGX, SLP sway bars, 3.42/LSD, Wings West kit, Z06 Motorsports, Silverstone Metallic paint<br /><a href=\"http://www.shift5.com/\" target=\"_blank\">Shift 5</a> - My Band
