i was planning on purchasing the powerpak but now im hearing all this about its not worth it and a cam swap would be just as effective. what do u guys suggest i do? powerpak or a cam and maybe a valvetrain rebuild?
supersix or straight up cam swap?
If you want all out NA performance you'll need a set of heads.
If you just want some more power at a more affordable price, than a cam only may be what you want.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
A cam without no headwork would be worthless to me , but thats my opinion. The supersix powerpack with heads/cam/intakes would definetly give you a more hp gain.2002 Grand Prix GTP- FWI Intake , flowmaster 40\'s ,3.4 pulley , and Intense racing PCM.<br />94 3.4L camaro -Lots of mods!
<blockquote>quote:</font><hr>Originally posted by slomaro:
hrmm 20-30hp easy with just a cam is worthless? for a little over 300 bucks
you dont know **** shut the **** up<hr></blockquote>
Now,lets not act out of hand here.If you read my post then you will see that it say that its "MY OPINION".2002 Grand Prix GTP- FWI Intake , flowmaster 40\'s ,3.4 pulley , and Intense racing PCM.<br />94 3.4L camaro -Lots of mods!
tell me what other mod besides a nitrous kit will give you 20-30 hp for 3-400 dollars
NOTHING not a thing hell a converter cost more money then a cam swap and most people dont understand how easy a cam swap is
actlly unless your gonna get a big ol cam with lift above .500 then then there is no reason really to get p&p heads if your just looking to pick up 20-30 hp not everyone wants a race car.
if you do a heads and cam install it will cost you over 1K easy
300 cam
150 spring
retainers
bolts and gaskets 150 - 200
p&p heads 200 or so if you do them your self and get a 3 angle valave job done on them or 800 if you dont wanna bother with heads
hrmmmm and if you put a big cam in you gotta get you pcm programed or its not really worth it and if you have an auto then a converter it adds up fast
a simple GT cam is good for at min 20 hp should put an auto even in the 200 rwhp range
hell ironman24 installed a pussy little reground cam and layed down 220 n/a rwhp with his manual so to say a cam is not worth it is BS iromans cam is a weak cam with not even .450 lift you can go to .500 on stock heads before it really tapers off
in that case, would getting the heads with the 3 angle valve job from supersix, not touch the manifolds and get a fairly larger cam from some other vendor be a decently good approach? or should i do it all thru TomSLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
300 cam
150 spring
retainers
hell ironman24 installed a pussy little reground cam and layed down 220 n/a rwhp with his manual so to say a cam is not worth it is BS iromans cam is a weak cam with not even .450 lift you can go to .500 on stock heads before it really tapers off<hr></blockquote>
Damn, I really didnt know that, ive alway thought on not too big cams .You can probly say I dont have the biggest cam in the world(powermax 2030 204/214 109 LSA .451/.451 lift with 1.6 gold series rockers) but hoping I can get some pretty good power out of it . I always guessed my cam would only produce 15 hp at most but what would you think?2002 Grand Prix GTP- FWI Intake , flowmaster 40\'s ,3.4 pulley , and Intense racing PCM.<br />94 3.4L camaro -Lots of mods!
where are you guys getting 300 for a cam? is that cam and install, or just cam, im looking into a cam and ammp has them for like $180, and the cheepest cam install i have found is like 500 so if that the 300 is for both, i want to see where you guys are getting your work done atFighting Texas Aggie class of 2008<br />black 3.4 T-top bird<br />- K&N CAI - magnaflo catback - slect coils - catco cat - tb coolant bypass
I didnt say anything about a cam being 300 dollars.Your cam is about a right price from what ive seen.Oh and 500 dollars is about right for a cam install.2002 Grand Prix GTP- FWI Intake , flowmaster 40\'s ,3.4 pulley , and Intense racing PCM.<br />94 3.4L camaro -Lots of mods!
<blockquote>quote:</font><hr>Originally posted by FuryCharger:
in that case, would getting the heads with the 3 angle valve job from supersix, not touch the manifolds and get a fairly larger cam from some other vendor be a decently good approach? or should i do it all thru Tom<hr></blockquote>
The way im going is not through Tom but dont get me wrong,Tom knows excactly what he's doing and what he talks about.Im going a much cheaper route to a mechanic I know that owns half of a machine shop and also knows excactly what he's doing .Im having my heads ported with a 3 angle valve job with my intakes ported and polished as the same with my throttle body , and he's also installing a cam. He's installing much more but its just a long list and I dont feel like typing it all out.2002 Grand Prix GTP- FWI Intake , flowmaster 40\'s ,3.4 pulley , and Intense racing PCM.<br />94 3.4L camaro -Lots of mods!
what cam can you put in and still pass emmissions test? i was thinking of just putting the intese 1.9 rocker arms on to increase the lift of the stock cam. but it is more expensive $350 than a cam but it is easier to install. what is better to do for power and emmissions i need to drive the car so i dont want to have any probs. thans.
ok, figure a good Tc for about 450, and install for about 400. a cam will usually require springs as well, so about 300 for a comp cam, and 150 for springs. plus u need gaskets for 150, and labor for about 400 as well. heads from super six are 500, plus about 200 for the intakes, and labor is about 200.
Totals:
TC: 850
Cam: 1000
Heads/Intakes: 900
cam will get u the most hp, heads will get u set for an even bigger cam in the future, and TC is off the subject, but somebody else mentioned it earlier.2001 Arctic White Firebird<br />More mods than I\'m allowed to list!
Couldn't you just buy part of the powerpack (heads/intake) and then buy a custom grind comp cam or something?? I'm not expert by any means, but I know there are some ssm heads for sale in the for sale section (there were a little while ago though, they could still be there) and then buy a nice custom cam? Is the question more of what's the best way to go for more N/A power with money as no object, or what is the best bang for the buck engine mod?AIM: Alientr8tr<br /><a href=\"http://www.cardomain.com/memberpage/583450\" target=\"_blank\">1998 Camaro 3.8L</a><br />Flowmaster 80-series, !FRA, Eibach Springs, KYB AGX, SLP sway bars, 3.42/LSD, Wings West kit, Z06 Motorsports, Silverstone Metallic paint<br /><a href=\"http://www.shift5.com/\" target=\"_blank\">Shift 5</a> - My Band
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.1 day ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...3 days ago
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....1 week ago
