Camshafts for 60 degree engines interchangable? - FirebirdV6.com/CamaroV6.com Message Board
  • Camshafts for 60 degree engines interchangable?
    I found a nice cam for GM 60 degree engines and it lists 2.8 and 3.1 motors but I know the 3.4 is the same damn thing. Will it work or not? :\
    Mustangs.. Come to the darkside...<br /><br />The dark side is the path to the shadow of greed. =D
    some of the 2.8 and 3.1 cams dont have a cam sensor trigger cast on them, that is the only difference.
      is that such a big deal..
      New:04 GMC Sierra 1500 RCLB 4x4 5.3 GU80 3.73\'s.<br />Truck pics<br />Mods<br />Go fast: Panel K&N filter and soon SS truck catback.<br />Appearance: Stull Billet grill,Weston Chrome step tubes,Rhino Chrome hitch step,ARE painted fiberglass cover,Silver star lighting.
        The cam trigger and the cam position sensor send the signal to the computer to handle the ignition firing. Yes, it is a big deal.
          Well it seems my crane 2030 cam dont have that..
            Wait. can someone show me a pic of what this is..
            I'm really confused..
              I believe that Tiago has that cam but isn't using it. You will probably have to affix some kind of notch to it so the computer knows the ignition timing.
                He told me earlier today that the SFI wont work, just hurts your Gas milage.
                  Don't 3.4's have a crank sensor?
                  I have herd that people run just the crank sensor.
                  I think it is a little button that sticks out, you will not be able to cut any thing in the cam.
                  Drill and tap a hole in the cam and stick a threded peace of steel or a round hex headed bolt in there and tack weld it on so it can't fall out.
                    Yea we have Crank sensors so the car can prob just go off that and be ok..
                      So the consensus is that it will work. I am at this problem right now. I have asked several people about this, and they all said it will run, just be a little rich, and kinda bad gas mileage. But it will run good, and strong. Thanks.
                        I don't have a pic, but it would be a bump between the first cam bearing journal and the first lobe
                        the 2030 should have it, as its for fuel injected motors
                          the crane 2030 doesnt have it found out the hard way
                          1995 Camaro 3.4 M5 - Project<br />1998 Camaro 3.8 A4 - Daily<br />Aim:V6OnSpeed<br /> <a href=\"http://www.cardomain.com/memberpage/576233/1\" target=\"_blank\">http://www.cardomain.com/memberpage/576233/1</a>
                            Sorry to hear that. Im in the same boat. How did your situation come out?
