i'm getting ready to install the maft+. were is the best place to splice into the signal wire and where is it located. also the is like 6 harnesses that came with the kit,. how many of these are going to be used? thank you
location of est signal wire for maft+
white wire behind the ICM.. pin A I believe..
Pinout diagrams are in the tech database in the engine section.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
i still can't find it, where is it located. can i splice itto the wire from the pcm side of the engine bay. what the hell is the icm97 CAMARO RS<br />12.9@103mph<br />best 60ft..1.9 ( on street tires)<br /> 1.7 (on gas)<br />turbo supra 12.5@119mph (street tires)<br />new times to come sporting the sp63gt
ICM is ignition control module (thin thing the coils sit on)
I followed the pin out guide and spliced into my wire about 1 foot out of the PCM. There was enough room to sauder there and I ran the wire down the AC lines to the MAFT+
http://www.carolinafbodyclub.com/iro...ftplus_jpg.htmMichael Huff<br />92 RS, 98 V6, 97 SS, 00 Z28 <br /> <a href=\"http://www.carolinafbodyclub.com/\" target=\"_blank\">http://www.carolinafbodyclub.com/</a>
