Read some autotap logs for me? - FirebirdV6.com/CamaroV6.com Message Board
  • Read some autotap logs for me?
    I know John D helped me some but I'd like some more opinions, as I don't really know how to read it well.
    http://www.mymilkexpired.com/tempsto...turbov6log.xls
    Can anyone check that out, I'm pretty sure it's going lean, which is probably causing the knock.
    Now I am misfiring in cyl 1 and 3, which is probably from fouling the plugs, but I will check when I get back in town. Car was not misfiring for those logs, it was healthier then.
    sorry for being a little off topic... but when you say fouling the plugs... what do you mean?
    anyways.. wish i could read autotap.. but i dont. good luck with peoples help. (i need autotap :mad: )
    96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
      Since its misfiring in two cylinders and it started around the same time, I probably gunked up one of the plugs due to a lean condition, and they are toast, causing the spark signal to be off... misfire.
        no one will take a look?
          <blockquote>quote:</font><hr>Originally posted by xjarayax:
          Since its misfiring in two cylinders and it started around the same time, I probably gunked up one of the plugs due to a lean condition, and they are toast, causing the spark signal to be off... misfire.<hr></blockquote>
          Lean will clean the plugs... If anything, it might have melted the ground electrode. Probably need to check the plugs on that bank that's going lean and see what they look like. Weird that one bank still looks fine.
            so if a car is running rich the plugs will be black?
            Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
              Yep. (or also if there is oil getting past the rings or valves... - but then they will be getting gunky too.)
                you are running lean for boost.
