Ok, this has probably been beat to death and everyone is going to flip out with the "use the search button", but when swapping an LT1 into a 98 Firebird will the dash harness have to be changed as well?
I found a wrecked 97 Formula with 80k miles for 1500. It is a T56 with everything included except radiator and wiring harness. Everything is include from the entire front end assembly, k-member, computer, and driveshaft.
Hey, sounds like a good deal for a swap... but wouldn't it be easier to put in an LS1?
Check out my stable of supercharged W-Bodies <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=136\" target=\"_blank\">HERE</a><br /><b>\'97 Pontiac GP GTP Coupe</b><br /><b>\'98 Regal GS | L67 3800 Series II</b>
