If I were to remove my powerstearing and Ac, and were to put in an electric water pump. Could i find a belt the size i need to run just my altenator?
ac and power stearing removal
yeah, you should type up a how to while you're at it ;)
[ September 05, 2005, 04:08 PM: Message edited by: 99v6cam ]\'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
This is my ultimate plan, basically you wouldn't be able to leave the alternator in its current position because the water pump would get in the way. What would work is if you moved the alternator down next to the crank, either where the power steering is or the ac is. You would have to come up with some sort of mount for it, and put it on a swing type mount so that you wouldn't need a tensioner. Nobody that I know of has done it, but if you can make it work, let us know. Once I get rid of my powersteering I'll be able to play around with this some more.
g2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
I was gonna say can't keep it in the stock place..
I have tried to see if I could rig a belt for just crank, waterpump and alt, can't do it...
but man, you guys are crazy for !ac and !power steering.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
maybe instead of a belt have a full pulley system lol
let me know when you do it so i can do it2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
and please help relocate my battery, ac, alt, power steering, wp, all to the rear. thnx2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
I'm sure the engine bay will look alot cleaner and your arms are going to be twice as big trying to turn the wheel.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
Originally posted by camaro boy:
All My budies with Hondas, we always pull the power stearing off before an engine swap. The car handles alot beter when going fast but it is a b!$^h in a parking lot.
Go pull your drivebelt and go for a quick drive down teh street and back.(make sure car is dead cool, when you do this it will heat up fast)
Might be able to do a manual steering conversion like 12sec, but I think its a bit crazy for a daily driver.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
i heard it will hurt the crank or something if your belt snaps?
will it just heat up really hot real quick or will your engine blow up?
my belt is about to snap2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
A quick trip down the track or around the block won't hurt it, just keep an eye on the temp. ;)
Also note that the alternator won't be turning either, so you'll drain the battery in addition to melting your engine. [img]tongue.gif[/img]Matt
1998 Mystic Teal Camaro M5
Change it ASAP...
you won't hurt the crank without it.
but you will overheat, since you are not pumping coolant through your motor(no waterpump since the belt isn't cranking it) YOu can probably drive the car from dead cool for about 1-2 minutes before it starts to get really hot. So keep that in mind.
Also you will be running the car off of the battery only, since the alternator isn't working as well.
I am just suggesting it so you can see how hard it is to drive with no Powersteering in an f-body.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....3 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.3 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
